Raster layers from PNG + .wld file
Stephen Davies
sdc at SDC.COM.AU
Tue Jan 24 05:13:04 EST 2006
G'day all.
I have been successful in using ECW files as raster layers but am now
trying to use a PNG file plus a .wld file with blank results.
My test map file looks like this:
MAP
NAME test
EXTENT 735810 8454630 742810 8461630
PROJECTION
"init=epsg:28352"
END
SIZE 600 600
FONTSET "/usr/local/apache2/htdocs/benparts/fonts.list"
SYMBOLSET "/usr/local/apache2/htdocs/benparts/symbols"
UNITS METERS
IMAGETYPE png24
IMAGECOLOR 255 255 255
WEB
template /usr/local/apache2/htdocs/benparts/templates/test1.html
imagepath "/usr/local/apache2/htdocs/tmp/"
imageurl "/tmp/"
END
LAYER
TYPE RASTER
NAME "bkgrnd"
STATUS DEFAULT
PROJECTION
"init=epsg:28352"
END
DATA "/usr/local/apache2/htdocs/benparts/rasters/dd1.png"
PROCESSING "DITHER=YES"
END
END
My dd1.wld file looks like:
2.1
0.0000000000
0.0000000000
-2.1
746046.00
8450252.00
The URL:
http://www.sdc.com.au/cgi-bin/mapserv?map=/tmp/test.map
gives no errors and an empty display.
What am I doing wrong?
Cheers and thanks,
Stephen Davies
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
