Layer order {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Tue Jan 24 10:50:49 EST 2006
You have an extra end in the definition of your last layer.
Check LAYER ... END and CLASS ... END pairs.
Bye
Zoltan
On Tue, 24 Jan 2006, Ruiter E. de (Erik) wrote:
> Hi list,
> I've a small problem with my mapfile..
> I want to have the layer 'verblijfsobjecten' always on top. When I place
> the layer at the end of my mapfile I get this error:
> msWMSLoadGetMapParams(): Invalid layer(s) given in the LAYERS parameter.
> When I have the layer like in my mapfile below it does work but the
> layer is not on top....
> Anyone can help me with this?
> Greets,
> Erik.
> # MAPFILE Spinoffice
> #============ MAIN MAP
> MAP
> NAME "Spinoffice"
> SIZE 400 200
> EXTENT 123161.184000 425974.862000 130445.273000 430555.785000
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> SHAPEPATH "shapes"
> SYMBOLSET "symbols35.sym"
> WEB
> TEMPLATE "../html/mapserver.html"
> IMAGEPATH '/ms4w/tmp/ms_tmp/'
> IMAGEURL '/ms_tmp/'
> END
> PROJECTION
> "init=epsg:28992"
> END
> #============ LAYERS
> LAYER
> NAME Gebouwen
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE oraclespatial
> CONNECTION "bag/bag at maatwerk"
> DATA "N0320 FROM GEBOUW USING SRID 90112"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> PROJECTION
> "init=epsg:28992"
> END
> CLASS
> NAME "gebouw"
> SIZE 1
> STYLE
> COLOR 255 0 0
> OUTLINECOLOR 32 32 32
> END
> END
> END
> LAYER
> NAME GBKG
> TYPE LINE
> STATUS OFF
> DATA gbkg_l
> PROJECTION
> "init=epsg:28992"
> END
> CLASS
> NAME "gbkg"
> STYLE
> COLOR 190 190 190
> OUTLINECOLOR 190 190 190
> END
> END
> END
> LAYER
> NAME Buurten
> TYPE LINE
> STATUS OFF
> DATA buurten
> PROJECTION
> "init=epsg:28992"
> END
> CLASS
> NAME "buurten"
> STYLE
> COLOR 0 0 0
> OUTLINECOLOR 100 100 100
> END
> END
> END
> LAYER
> NAME Wegvakken
> TYPE LINE
> STATUS OFF
> DATA wegvakken
> PROJECTION
> "init=epsg:28992"
> END
> CLASS
> NAME "wegvakken"
> STYLE
> COLOR 190 190 190
> END
> END
> END
> LAYER
> NAME Verblijfsobjecten
> TYPE POINT
> STATUS ON
> DATA "A5620 FROM VERBLIJFSOBJECT USING SRID 90112"
> PROJECTION
> "init=epsg:28992"
> END
> SYMBOLSCALE 10000
> CLASS
> NAME "verblijfsobject"
> STYLE
> SYMBOL "circle"
> COLOR 0 0 0
> # SIZE 7
> MAXSIZE 20
> MINSIZE 1
> END
> END
> END
> LAYER
> NAME Ligplaatsen
> TYPE POINT
> STATUS OFF
> DATA "A5820 FROM LIGPLAATS"
> PROJECTION
> "init=epsg:28992"
> END
> CLASS
> NAME "ligplaats"
> SIZE 1
> STYLE
> COLOR 0 0 255
> END
> END
> END
> LAYER
> NAME Panden
> TYPE POLYGON
> STATUS OFF
> DATA "A5520 FROM PAND USING SRID 90112"
> CLASS
> NAME "pand"
> SIZE 1
> COLOR 255 100 100
> END
> END
> END
> END
> [DISCLAIMER]
> Dit e-mail bericht is vertrouwelijk. Het is uitsluitend bestemd voor de geadresseerde.
> Indien u niet de geadresseerde bent, verzoeken we u dringend ons direct te informeren en om dit bericht en eventuele bijlage(n) te verwijderen, zonder het te kopieren, door te zenden of op enige andere wijze te openbaren of te gebruiken. ARCADIS is niet aansprakelijk voor welke schade dan ook als gevolg van communicatie per e-mail en verzending van documenten en gegevens.
> This e-mail is confidential and may also be privileged. It is intended for use by the addressee only.
> If you are not the intended addressee, we request that you notify us immediately and delete this e-mail, and any attachment(s), without copying, forwarding, disclosing or using it in any other way. ARCADIS will not be liable for damage relating to the communication by e-mail of data or documents.
