e00 to something OGR can read
Jerl Simpson
jerl.simpso at GMAIL.COM
Mon Jan 30 10:14:58 EST 2006
No idea how it was created.
But the easy work around is to fill in the class name. It works fine then.
Jerl
On 1/30/06, Shoaib Burq <hydromap at gmail.com> wrote:
> Daniel, Jerl
> Do you know how this file was created. Coz I ran into the same problem
> when I tried improting some E00 files (not sure about their source)
> and the reason for avcimport failing was an empty subclass name.
> Interestingly the conversion worked using ArcToolBox's "Import from
> Interchange File" which implies ArcInfo has no problems with empty
> subclass names.
> shoaib
> On 1/25/06, Daniel Morissette <dmorissette at dmsolutions.ca> wrote:
> > Jerl Simpson wrote:
> > > I forgot to mention something important.
> > > I receive this error:
> > > ERROR 5: Invalid TX6/TX7 subclass name "-8.6507622E+01 1.6335363E+01"
> > > I'm not sure if the program simply halts here and goes no further, if
> so
> > > that might be why I don't get the rest of the data.
> > I've seen this before and thought that the issue was fixed, or at least
> > documented in a bug, but I guess not.
> > I just created a avce00 bug about this, and included a way to work
> > around the issue until a fix is available:
> > http://bugzilla.maptools.org/show_bug.cgi?id=1261
> > Daniel
> > Daniel Morissette dmorissette at dmsolutions.ca
> > DM Solutions Group http://www.dmsolutions.ca/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060130/322c6c76/attachment.html
