e00 to something OGR can read
Shoaib Burq
hydromap at GMAIL.COM
Mon Jan 30 07:00:06 EST 2006
Daniel, Jerl
Do you know how this file was created. Coz I ran into the same problem
when I tried improting some E00 files (not sure about their source)
and the reason for avcimport failing was an empty subclass name.
Interestingly the conversion worked using ArcToolBox's "Import from
Interchange File" which implies ArcInfo has no problems with empty
subclass names.
shoaib
On 1/25/06, Daniel Morissette <dmorissette at dmsolutions.ca> wrote:
> Jerl Simpson wrote:
> > I forgot to mention something important.
> > I receive this error:
> > ERROR 5: Invalid TX6/TX7 subclass name "-8.6507622E+01 1.6335363E+01"
> > I'm not sure if the program simply halts here and goes no further, if so
> > that might be why I don't get the rest of the data.
> I've seen this before and thought that the issue was fixed, or at least
> documented in a bug, but I guess not.
> I just created a avce00 bug about this, and included a way to work
> around the issue until a fix is available:
> http://bugzilla.maptools.org/show_bug.cgi?id=1261
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
