e00 to something OGR can read
Jerl Simpson jerl.simpso at GMAIL.COM
Tue Jan 24 08:36:53 PST 2006
it's named .E00
I tried the dos2unix and no change.
These files are already unix text files.
On 1/24/06, Lowell.Filak <lfilak at medinaco.org> wrote:
> Jerl Simpson writes:
> > I forgot to mention something important.
> > I receive this error:
> > ERROR 5: Invalid TX6/TX7 subclass name "-8.6507622E+01 1.6335363E+01"
> > I'm not sure if the program simply halts here and goes no further, if so
> > that might be why I don't get the rest of the data.
> > On 1/24/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> >> On 1/24/06, Jerl Simpson <jerl.simpso at gmail.com> wrote:
> >> > Hello,
> >> > I'm looking for a program that will convert e00 files to something
> OGR
> >> can
> >> > read.  Preferrably ESRI Shape files, but I really don't care.
> >> > I found e002shp but it doesn't seem to retain all the information I
> >> need.
> >> > There might be multiple versions of e002shp or even different
> authors.
> >> > It would be best if I could do this command line in a *nix
> environment.
> >> > If anyone has any suggestions I'd love to know.  I've tried to do
> this
> >> > before but with little luck.
> >> Jerl,
> >> I would suggest you use the "avcimport" program to convert the
> >> E00 file to an arc/info binary vector coverage which OGR can
> >> read.
> >>   http://avce00.maptools.org/
> Jerl,
> Is the e00 file you're trying to use named ".e00" or is it ".e01' or
> ".e02"?
> Also, could it be a DOS text file and you're tring to import on Unix
> without
> first doing dos2unix on it?
> Lowell
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060124/b84dedf2/attachment.htm>
More information about the MapServer-users mailing list
