Horrible Looking WMS Raster Imagery
Jennifer Zeisloft
jzeisloft at GMAIL.COM
Tue Jan 24 11:55:46 EST 2006
Hi Bart,
That was exactly what I needed to do. The problem is fixed!
Thanks for all the help!
Jennifer
On 1/24/06, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl>
wrote:
> Jennifer,
> try to use PNG24 for the parameter named image_type in chameleon.xml.
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> *Van:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]*Namens
> *Jennifer Zeisloft
> *Verzonden:* dinsdag 24 januari 2006 6:04
> *Aan:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Onderwerp:* Re: [UMN_MAPSERVER-USERS] Horrible Looking WMS Raster Imagery
> Hi Frank,
> Thanks for the response, Frank. It is sounding more and more like this is
> a question I ought to forward to the chameleon list - because I am also not
> sure how to generate 24bit output with chameleon!
> I appreciate the much needed direction!
> Thanks all!
> Jennifer
> On 1/23/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > On 1/23/06, Brent Pedersen <bpederse at nature.berkeley.edu> wrote:
> > > have you tried using image/jpeg?
> > In addition to fetching data from the remote WMSes as
> > JPEG, it is also necessary for mapserver to generate 24bit
> > output (JPEG or PNG24 for instance). I don't know how to
> > do that with Chameleon myself, but I'm sure there is a setting
> > somewhere.
> > I think Ed is right that the problem is 24bit to 8bit color
> > conversion with correspondingly poor color resolution.
> > Given sufficient blotchiness from this conversion it can
> > even appear that spatial resolution is degraded (though it
> > isn't actually).
> > Best regards,
> > I set the clouds in motion - turn up | Frank Warmerdam,
> > light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> > and watch the world go round - Rush | Geospatial Programmer for Rent
> Disclaimer
> ************************************************************************ Aan
> dit bericht kunnen geen rechten worden ontleend. Dit bericht is uitsluitend
> bestemd voor de geadresseerde. Als u dit bericht per abuis hebt ontvangen,
> wordt u verzocht het te vernietigen en de afzender te informeren. Wij
> adviseren u om bij twijfel over de juistheid of de volledigheid van de mail
> contact met afzender op te nemen. This message shall not constitute any
> rights or obligations. This message is intended solely for the addressee. If
> you have received this message in error, please delete it and notify the
> sender immediately. When in doubt whether this message is correct or
> complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060124/600cfee6/attachment.html
