Horrible Looking WMS Raster Imagery
Ed McNierney ed at TOPOZONE.COM
Tue Jan 24 10:28:24 PST 2006
Jennifer -
If your output is photographic, you may find JPEG to be a better output
format choice.  The image files will be much smaller.  Now that you know
how to control the output format, you should experiment to see which
format works best for you.
     - Ed
Ed McNierney
TopoZone.com
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jennifer Zeisloft
Sent: Tuesday, January 24, 2006 11:56 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Horrible Looking WMS Raster Imagery
Hi Bart,
That was exactly what I needed to do.  The problem is fixed!
Thanks for all the help!
Jennifer
On 1/24/06, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl>
wrote:
	Jennifer,
	try to use PNG24 for the parameter named image_type in
chameleon.xml.
	Best regards,
	Bart
		-----Oorspronkelijk bericht-----
		Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Jennifer Zeisloft
		Verzonden: dinsdag 24 januari 2006 6:04
		Aan: MAPSERVER-USERS at LISTS.UMN.EDU
		Onderwerp: Re: [UMN_MAPSERVER-USERS] Horrible Looking
WMS Raster Imagery
		Hi Frank,
		Thanks for the response, Frank.  It is sounding more and
more like this is a question I ought to forward to the chameleon list -
because I am also not sure how to generate 24bit output with chameleon!
		I appreciate the much needed direction!
		Thanks all!
		Jennifer
		On 1/23/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
			On 1/23/06, Brent Pedersen
<bpederse at nature.berkeley.edu> wrote:
			> have you tried using image/jpeg?
			In addition to fetching data from the remote
WMSes as
			JPEG, it is also necessary for mapserver to
generate 24bit
			output (JPEG or PNG24 for instance).  I don't
know how to
			do that with Chameleon myself, but I'm sure
there is a setting
			somewhere.
			I think Ed is right that the problem is 24bit to
8bit color
			conversion with correspondingly poor color
resolution.
			Given sufficient blotchiness from this
conversion it can
			even appear that spatial resolution is degraded
(though it
			isn't actually).
			Best regards,
			I set the clouds in motion - turn up   | Frank
Warmerdam, warmerdam at pobox.com
			light and sound - activate the windows |
http://pobox.com/~warmerdam <http://pobox.com/%7Ewarmerdam>
			and watch the world go round - Rush    |
Geospatial Programmer for Rent
	Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen. This message
shall not constitute any rights or obligations. This message is intended
solely for the addressee. If you have received this message in error,
please delete it and notify the sender immediately. When in doubt
whether this message is correct or complete, please contact the sender.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060124/00bdb25b/attachment.htm>
More information about the MapServer-users mailing list
