Horrible Looking WMS Raster Imagery
Jennifer Zeisloft
jzeisloft at GMAIL.COM
Tue Jan 24 13:40:38 EST 2006
JPEG looks great as well - thanks much for the tips!
Jennifer
On 1/24/06, Ed McNierney <ed at topozone.com> wrote:
> Jennifer -
> If your output is photographic, you may find JPEG to be a better output
> format choice. The image files will be much smaller. Now that you know how
> to control the output format, you should experiment to see which format
> works best for you.
> - Ed
> Ed McNierney
> TopoZone.com
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
> Behalf Of *Jennifer Zeisloft
> *Sent:* Tuesday, January 24, 2006 11:56 AM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] Horrible Looking WMS Raster Imagery
> Hi Bart,
> That was exactly what I needed to do. The problem is fixed!
> Thanks for all the help!
> Jennifer
> On 1/24/06, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl>
> wrote:
> > Jennifer,
> > try to use PNG24 for the parameter named image_type in chameleon.xml.
> > Best regards,
> > Bart
> > -----Oorspronkelijk bericht-----
> > *Van:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]*Namens
> > *Jennifer Zeisloft
> > *Verzonden:* dinsdag 24 januari 2006 6:04
> > *Aan:* MAPSERVER-USERS at LISTS.UMN.EDU
> > *Onderwerp:* Re: [UMN_MAPSERVER-USERS] Horrible Looking WMS Raster
> > Imagery
> > Hi Frank,
> > Thanks for the response, Frank. It is sounding more and more like this
> > is a question I ought to forward to the chameleon list - because I am also
> > not sure how to generate 24bit output with chameleon!
> > I appreciate the much needed direction!
> > Thanks all!
> > Jennifer
> > On 1/23/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > > On 1/23/06, Brent Pedersen <bpederse at nature.berkeley.edu> wrote:
> > > > have you tried using image/jpeg?
> > > In addition to fetching data from the remote WMSes as
> > > JPEG, it is also necessary for mapserver to generate 24bit
> > > output (JPEG or PNG24 for instance). I don't know how to
> > > do that with Chameleon myself, but I'm sure there is a setting
> > > somewhere.
> > > I think Ed is right that the problem is 24bit to 8bit color
> > > conversion with correspondingly poor color resolution.
> > > Given sufficient blotchiness from this conversion it can
> > > even appear that spatial resolution is degraded (though it
> > > isn't actually).
> > > Best regards,
> > > I set the clouds in motion - turn up | Frank Warmerdam,
> > > light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> > > and watch the world go round - Rush | Geospatial Programmer for
> > > Rent
> > Disclaimer
> > ************************************************************************ Aan
> > dit bericht kunnen geen rechten worden ontleend. Dit bericht is uitsluitend
> > bestemd voor de geadresseerde. Als u dit bericht per abuis hebt ontvangen,
> > wordt u verzocht het te vernietigen en de afzender te informeren. Wij
> > adviseren u om bij twijfel over de juistheid of de volledigheid van de mail
> > contact met afzender op te nemen. This message shall not constitute any
> > rights or obligations. This message is intended solely for the addressee. If
> > you have received this message in error, please delete it and notify the
> > sender immediately. When in doubt whether this message is correct or
> > complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060124/4ff26395/attachment.html
