dynamic referencemap
ruth schÿfffff6nbuchner
ruthschoenbuchner at YAHOO.DE
Tue Jan 24 14:34:40 EST 2006
Hello "Mapscripters" and PHP experts,
I would like to make navigable the small general map in my WebGIS application. If one clicks into the reference map , the large map should change. (f.e.to zoomin or just to go to the selected part of the map?).
I picked out from "GMap", that with click into the reference map (similarly as with click into the large map),the two variables (keymap_x/keymap_y) are handed over, which define then the new map center of the main map.
Can someone did program coincidentally already times this procedure and give oneself tips?
F.e.does the reference map need an extra map file(Gmap says so) and, how that, embedded apart from the main map file into the MapScript?
Thank you for suggestions,¦ Ruth
Telefonieren Sie ohne weitere Kosten mit Ihren Freunden von PC zu PC!
Jetzt Yahoo! Messenger installieren!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060124/e700795a/attachment.html
