ogr personal geodatabase issue
Frank Warmerdam
warmerdam at POBOX.COM
Tue Jan 24 17:46:40 EST 2006
On 1/24/06, Jim Donaghy <jim at jimdonaghy.com> wrote:
> I am connecting to an esri .mdb file using ogr, but unable to display
> the shapes in it. Running the ogrinfo utility displays the data in the
> mdb tables correctly, but when I use the connection in a map file it
> displays a blank image. No error is displayed. Below is the relevant
> layer from my map file.
> LAYER
> NAME "area"
> CONNECTIONTYPE OGR
> CONNECTION "d:/geodata/test.mdb"
> DATA "Areas"
> TYPE POLYGON
> STATUS DEFAULT
> CLASS
> STYLE
> COLOR 199 215 158
> END
> END
> END
> I'm using the latest distribution of MS4W. Is defining a class for this
> kind of layer different from using a shape file as the data source?
Jim,
The above looks fine assuming your .mdb file contains a
geospatial layer called "Areas" with polygons in it. Also,
keep in mind that different permissions issues could apply
in a web context. I don't know much about this aspect.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
