ogr personal geodatabase issue
Jim Donaghy
jim at JIMDONAGHY.COM
Tue Jan 24 16:48:09 EST 2006
I am connecting to an esri .mdb file using ogr, but unable to display
the shapes in it. Running the ogrinfo utility displays the data in the
mdb tables correctly, but when I use the connection in a map file it
displays a blank image. No error is displayed. Below is the relevant
layer from my map file.
LAYER
NAME "area"
CONNECTIONTYPE OGR
CONNECTION "d:/geodata/test.mdb"
DATA "Areas"
TYPE POLYGON
STATUS DEFAULT
CLASS
STYLE
COLOR 199 215 158
END
END
END
I'm using the latest distribution of MS4W. Is defining a class for this
kind of layer different from using a shape file as the data source?
Thanks,
Jim
