Latest dbox.js?
Brent Fraser
bfraser at GEOANALYTIC.COM
Wed Jan 25 10:51:14 EST 2006
David,
Thank you! You were right; it was the path naming that was causing the
problem. I changed "javascript\cross-browser.com\" to
"javascript\cross_browser_com\" and the error disappeared. It looks like
Window's ISS has a problem with "." in the web paths.
Thanks to Rich G, Steve L, Mark W, and Frank B for helping me out. Simply
astounding support.
Thanks,
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
From: "Fawcett, David" <David.Fawcett at STATE.MN.US>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, January 25, 2006 7:34 AM
Subject: Re: [UMN_MAPSERVER-USERS] Latest dbox.js?
Brent,
I ran in to this same error several months ago when I re-acquired the
latest version of Steve's code.
If I remember correctly, this error was related to the js includes. The
main page/script wasn't able to access all of the includes.
Try to hit all of the URLs for the includes in the main document. If
you are on a Windows machine, the likely issue is that one of the
directories that he set up, the one with the X code in it has a name
that contains a '.', Windows coughed on that one.
Otherwise, check the permissions for the dirs where the includes are
located.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Brent Fraser
Sent: Tuesday, January 24, 2006 4:18 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Steve,
Many thanks. Is there a packaged/zipped download of the Landview
app
(map file, templates, gifs, but geo-data not necessary) available? I'd
like to try it with my own data, but I can't seem to get past a
javascript error in dBox_initialize:
this.anchor = window.xGetElementById(name);
causes an error: "Object doesn't support this property or method". I
suspect I haven't included/initialized the cross-browser stuff
properly...
Thanks!
Brent
To: <bfraser at GEOANALYTIC.COM>; <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, January 24, 2006 2:49 PM
Brent: It's at http://maps.dnr.state.mn.us/javascript/dbox.js. I'm going
to be adding support for a general drawing canvas shortly. Let me know
if you're interested...
Steve
>>> Brent Fraser <bfraser at GEOANALYTIC.COM> 01/24/06 3:39 PM >>>
Rich,
Where can I get the latest and greatest dbox.js?
Thanks!
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
