MS + PostGIS no rows detection?
Jesse Cleary
jcleary at EMAIL.UNC.EDU
Wed Jan 25 11:45:26 EST 2006
Hi folks
I'm trying to determine a programmatic method to determine when a
PostGIS layer query in MapServer returns no rows/empty, beyond not
seeing the data on the map. I am setting my FILTER string interactively
using MapScript - sometimes the user's choice does not return any rows
from the DB. In that case, I would like to substitute a small "No Data
Available" label on the map instead of the data.
I thought about implementing this through a separate label layer in my
mapfile, but "no rows" will not return any geometry to use for my "No
Data" labeling. I have tried using inline FEATUREs to handle the label
geometry, querying the DB using the same filter, and setting my class
expression to detect empty values for any field ( '[field]' = '' ).
However, this does not work - I think inline features override the
DATA, CONNECTION, or FILTER parameters and hence no DB querying takes
place at all.
I am open to using PHP/MapScript if that could work better - I could
then rewrite the label layer DATA string to point to a static "No Data"
shapefile. Or perhaps this requires a separate DB table with label-only
text and geometry, populated with only the empty time slices missing
from my main geom table?
Hoping there are some clever ideas that I have overlooked. I'm just not
able to wrap my head around which option to investigate further. Thanks
for any suggestions y'all might have!
Jesse Cleary
MapServer 4.2.5, PostgreSQL 8.0.5, PostGIS 1.0.4-2
Jesse Cleary
Department of Marine Sciences
UNC Chapel Hill
17-6 Venable Hall
jcleary at email.unc.edu
(919) 962-4323
