Dhtml mapserver (mapserv.js) panningtool
Wim Blanken
w.blanken at GEON.NL
Thu Jan 26 10:59:09 EST 2006
Hello Xavier,
A while ago I used this functionality in dbox. It is visible on this site:
http://207.44.178.94/watlas/
You have to use the button called 'schuiven' (sorry this site is in dutch)
and then
you can drag the map to a new position.
It has been a while since I made this site and i do not have much
documentation but maybe you are helped looking at the source and the
javascript libraries i used to implement this. Feel free to do so.
Regards,
Wim Blanken
The Netherlands
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, January 26, 2006 3:58 PM
Subject: Re: [UMN_MAPSERVER-USERS] Dhtml mapserver (mapserv.js) panningtool
> I've not implemented that functionality for dbox.js. Sorry.
> Steve
>>>> Xavier mauclaire <xavier.mauclaire at STRATEGIS.FR> 01/26/06 1:49 AM >>>
> Hi
> Thanks for your response.
> I know about the pan method.
> What i would like to do is allowing the user to drag & drop the image to
> simulate the pan deplacement.
> I think that you can do that with the java applet but a can't use it
> regards
> Xavier
> -----Message d'origine-----
> De : Steve Lime [mailto:steve.lime at dnr.state.mn.us]
> Envoyé : mercredi 25 janvier 2006 17:47
> À : MAPSERVER-USERS at LISTS.UMN.EDU; xavier.mauclaire at STRATEGIS.FR
> Objet : Re: [UMN_MAPSERVER-USERS] Dhtml mapserver (mapserv.js) panningtool
> There is a pan method available in mapserv.js. You'd just attach code like
> (assuming the mapserv object is called ms):
> ms.pan('nw')
> to an image or a link. In my landview example it's something like:
> <a href="javascript:ms.pan('nw')"><img src="nw.gif"></a>
> You could also use an image event handler as well I imagine to trigger the
> pan. The application below does this:
> http://www.dnr.state.mn.us/maps/landview.html
> Steve
>>>> Xavier mauclaire <xavier.mauclaire at STRATEGIS.FR> 01/25/06 10:27 AM
> Hi
> I'm using mapserver with the mapserv.js javascript library. I would like
> to
> implement the panning tool but i don't konw how to do that. Currently,
> only
> the recenter tool can be used.
> Any help would be appreciated
> regards
> Xavier
