SLD / stretch images when using FE !
François-Xavier PRUNAYRE
fx.prunayre at OIEAU.FR
Wed Jan 25 12:06:08 EST 2006
Same problem with a complete WMS GetMap request :
http://services.sandre.eaufrance.fr/geos/zonage?SERVICE=WMS&VERSION=1.1.1&Request=GetMap&LAYERS=CIBA&WIDTH=300&HEIGHT=300&BBOX=-5,40,12,52&SRS=EPSG:4326
http://services.sandre.eaufrance.fr/geos/zonage?SERVICE=WMS&VERSION=1.1.1&Request=GetMap&LAYERS=CIBA&WIDTH=300&HEIGHT=300&BBOX=-5,40,12,52&SRS=EPSG:4326&SLD=http://sandre.eaufrance.fr/geo/sld/cibaExp.sld
http://services.sandre.eaufrance.fr/geos/zonage?SERVICE=WMS&VERSION=1.1.1&Request=GetMap&LAYERS=CIBA&WIDTH=300&HEIGHT=300&BBOX=-5,40,12,52&SRS=EPSG:4326&SLD=http://sandre.eaufrance.fr/geo/sld/cibaInBourgogne.sld
Thanks for your help. Francois
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Bart van den Eijnden (OSGIS)
Envoyé : mercredi 25 janvier 2006 17:44
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: [UMN_MAPSERVER-USERS] SLD / stretch images when using FE !
Your GetMap requests are not valid WMS requests, you need to specify (among
others):
-width and height in pixels
-bbox
Try to specify those and see how it goes.
Best regards,
Bart
François-Xavier PRUNAYRE wrote:
>Hello list, one question about SLD & Mapserver
>A simple GetMap request on a LAYER
>return a correct image.
>A GetMap on the same layer using SLD and filter <PropertyIsEqualTo>
>.1&Request=GetMap&LAYERS=CIBA&SLD=http://sandre.eaufrance.fr/geo/sld/ci
>baExp.sld
>return a correct image. (SLD used :
>http://sandre.eaufrance.fr/geo/sld/cibaExp.sld)
>A GetMap on the same layer using SLD and filter <Intersects>
>baInBourgogne.sld return an image which contains the object
>corresponding to the intersect query but the image is stretched (on the
>y axis) ...
>(SLD used : http://sandre.eaufrance.fr/geo/sld/cibaInBourgogne.sld)
>Any ideas ? Layers are in Oracle Spatial.
>Francois
OSGIS, Open Source GIS
http://www.osgis.nl
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or distribution
must be authorized.
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
