SLD / stretch images when using FE !
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Jan 25 12:50:08 EST 2006
Francois,
I looked into the code and possibly saw what would cause your problem .
I have entered a bug 1627 on this
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1627
. Is it possible for you to use the latest cvs source to do the tests ?
I would appreciate if you could update the bug report on this.
Thanks.
François-Xavier PRUNAYRE wrote:
>Hello list, one question about SLD & Mapserver
>A simple GetMap request on a LAYER
>http://services.sandre.eaufrance.fr/geos/zonage?SERVICE=WMS&VERSION=1.1.1&Request=GetMap&LAYERS=CIBA&
>return a correct image.
>A GetMap on the same layer using SLD and filter <PropertyIsEqualTo>
>http://services.sandre.eaufrance.fr/geos/zonage?SERVICE=WMS&VERSION=1.1.1&Request=GetMap&LAYERS=CIBA&SLD=http://sandre.eaufrance.fr/geo/sld/cibaExp.sld
>return a correct image. (SLD used :
>http://sandre.eaufrance.fr/geo/sld/cibaExp.sld)
>A GetMap on the same layer using SLD and filter <Intersects>
>http://services.sandre.eaufrance.fr/geos/zonage?SERVICE=WMS&VERSION=1.1.1&Request=GetMap&LAYERS=CIBA&SLD=http://sandre.eaufrance.fr/geo/sld/cibaInBourgogne.sld
>return an image which contains the object corresponding to the intersect query
>but the image is stretched (on the y axis) ...
>(SLD used : http://sandre.eaufrance.fr/geo/sld/cibaInBourgogne.sld)
>Any ideas ? Layers are in Oracle Spatial.
>Thanks for your help.
>Francois
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
