Change image resolution in mapfile
David Bitner
osgis.lists at GMAIL.COM
Wed Jan 25 15:58:23 EST 2006
What size in inches do you want the resulting map to be? If you want
an absolutely enormous 80"x80" poster, then yes you should set the
mapsize to 24000x24000, but I find it unlikely that you are trying to
create something that huge. First, determine what size in inches you
want your poster, then multiply that width and height by 300.
On 1/25/06, krishna S <kris_rock82 at yahoo.com> wrote:
> I want an exactly 300 dpi map, so do you mean to set the mapsize to
> 24000X24000 pixels ....
> Thanks for your reply ..
