reverse of click2map (convert geographic coordinates into pixel value)
Stuart Eve stuarteve at LPARCHAEOLOGY.COM
Thu Jan 26 14:33:09 PST 2006
Ok in case anyone's interested, here's how I solved the below problem:
My point theme is stored (in the shapefile) in LatLongs and so when I
loop through the features, I get bounding boxes ($bounds) in LatLongs.
My map however then gets projected into a different coordinate system
(ETRS-89 LCC) when its drawn.
So in order to get the map2click function to work, I needed to project
each bounding box (by using $bounds->project ) first and then run
map2click. Thanks for the code, Ace.
Hope this helps someone.
Stu
Stuart Eve wrote:
> Hi all,
> I'm trying to convert a geographic coordinate into a pixel value (i.e.
> the reverse of the click2map demo script).
> I have searched around and found Ace Suares' script:
> function map2click ( $map, $bounds ) {
>        $bounds_average_x = ( $bounds->maxx + $bounds->minx ) / 2;
>        $bounds_average_y = ( $bounds->miny + $bounds->maxy ) / 2;
>        $x_pct = ( ( $bounds_average_x - $map->extent->minx ) / (
> $map->extent->maxx - $map->extent->minx ) );
>        $y_pct = ( ( $bounds_average_y - $map->extent->miny ) / (
> $map->extent->maxy - $map->extent->miny ) );
>        $x_map = intval( $map->width * $x_pct );
>        $y_map = intval( $map->height * (1 - $y_pct) );
>        return array( $x_map, $y_map );
> But this doesn't seem to be working for me - it just returns a very
> big negative number.
> I am using a point theme - with the data stored in LatLongs.
> Has anyone seen a script to do this?
> Thanks in advance,
> Stuart
Stuart Eve
L - P : Archaeology
stuarteve at lparchaeology.com
More information about the MapServer-users mailing list
