PHP MapScript and unable to load dynamic library
robert fritz
robert-fritz at WEB.DE
Tue Jan 31 03:08:22 EST 2006
Hi Brian,
did you put all the additional mapserver dlls in a folder, which is part of the Windows PATH variable?
robert
>I was wondering if anyone else has run into this problem. I am running Windows 2000 server with IIS5.0 and using the PHP MapScript dll MapServer 4.8 beta 2 for PHP 4.4.1 from maptools.org. >I have installed this version on one server and it works fine, but when I try to install it on another server I continue to get PHP Warning: dl(): Unable to load dynamic library '>C:\php\extensions\php_mapscript_48.dll' - The specified module could not be found. PHP is working fine and I can load another module, like GD, but not mapscript.
>I seem to be having the same problem as outlined in http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0402/msg00281.html. I have tried everything suggested, but still get the >error. My guess is I might be missing a .dll, but it appears I have everything I need. I am stumped why it is working on one server and not the other. Anyone have any insight?
______________________________________________________________________
XXL-Speicher, PC-Virenschutz, Spartarife & mehr: Nur im WEB.DE Club!
Jetzt gratis testen! http://freemail.web.de/home/landingpad/?mc=021130
