disable png interlacing?
Sears, Jeremy
Jeremy.Sears at CCRS.NRCAN.GC.CA
Tue Jan 31 08:29:40 PST 2006
Hi All,
Im wondering if its possible, and if so how to disable interlacing on
Mapserver's generation of png images? Also If it is possible to produce
non-interlaced png imagery, can anyone say if it would affect mapserver's
preformance?
Many Thanks
Jeremy
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Jeff McKenna
Sent: January 31, 2006 11:03 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] PHP MapScript and unable to load
dynamic library
A trick i also use to find which associated dll is missing is to try to
do a 'mapserv -v' at the command prompt, for your 4.8 exe. If a dll
cannot be found a Windows error message should be displayed (such as
"procedure entry point...cannot be found in gdal13.dll" or something
like that).
jeff
Fischer, Brian wrote:
> I was wondering if anyone else has run into this problem. I am running
> Windows 2000 server with IIS5.0 and using the PHP MapScript dll
> MapServer 4.8 beta 2 for PHP 4.4.1 from maptools.org. I have installed
> this version on one server and it works fine, but when I try to install
> it on another server I continue to get PHP Warning: dl(): Unable to load
> dynamic library 'C:\php\extensions\php_mapscript_48.dll' - The specified
> module could not be found. PHP is working fine and I can load another
> module, like GD, but not mapscript.
> I seem to be having the same problem as outlined in
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0402/msg00281.html.
> I have tried everything suggested, but still get the error. My guess
> is I might be missing a .dll, but it appears I have everything I need.
> I am stumped why it is working on one server and not the other. Anyone
> have any insight?
> Thanks,
> Brian
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
More information about the MapServer-users
