problem in compiling 4.8-rc3
John Cartwright
john.c.cartwright at NOAA.GOV
Tue Jan 31 23:44:27 EST 2006
Hi Sean,
good suggestion! Changing the order of the GDAL libs allows the configure
script to run even when one gives the location of the graphics libs
explicitly. As I mentioned earlier, it also works for me if one doesn't
give the location of the graphics libs, but allows the default. This fix
did not seem to address the problems on the Mac so there may be something
else going on there.
Also when using the Oracle Spatial option (Oracle client 10.2), I had to add
the libnnz10 to ORACLESPATIAL_LIB in the Makefile.
thanks again for your help!
-- john
On Sun, 29 Jan 2006 11:10:02 -0700, Sean Gillies <sgillies at FRII.COM> wrote:
>John,
> From a quick peek at the configure script, looks to me that when you
>specify --with-png, --with-jpeg, or --with-zlib paths, these
>locations are searched for GD *before* the --with-gd location.
>I've been avoiding this problem by not explicitly configuring --with-
>png etc. I think that I see a potential fix for the configure script.
>Wanna try something for me? On (or near) line 5666 change
>LIBS="-lgd $GD_XTRA_LIBS -L$GD_LIBDIR $LIBS"
>to
>LIBS="-lgd -L$GD_LIBDIR $GD_XTRA_LIBS $LIBS"
>We want the extra locations searched *after* the location you specify
>with --with-gd. This seems to be tripping people up all of a sudden,
>maybe there has been a recent change.
>By the way, if you are using GDAL, you should configure --without-tiff.
>cheers,
>Sean
