Mapscript mapObj.save() to write out multiple outputformats
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Jul 3 04:55:51 EDT 2006
Gee, sorry I misread your question (it's monday morning....)
Dunno why it doesn't work tough.
Umberto
On 7/3/06, Shoaib Burq <hydromap at gmail.com> wrote:
> Humm... not so sure if the map.draw applies to what we are trying to
> do... according to the Mapscript API docs map.draw() returns an
> imageObj, while we are trying to write-out a mapfile with multiple
> outputFormat definitions in it.
> This functionality should be part of the map.save() method but I am
> beginning to think it's not implemented.
> On 7/3/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> > You probably have to loop over all the formats you need and for every
> > format do something like:
> > map.setOutputFormat
> > map.draw
> > hth,
> > Umberto
> > On 7/1/06, Shoaib Burq <hydromap at gmail.com> wrote:
> > > Hi all
> > > we are trying to create a mapfile on the fly and need to add multiple
> > > outputformats to the mapfile. we can use the
> > > appendOutputFormat(new_OF) in python-mapscript. However when using the
> > > mapObj.save(mymapfile.map) to write our map object to file, it only
> > > writes-out the last format appened.
> > > The only relavent code i found was in:
> > > mapserver/mapscript/python/tests/cases/outputformattest.py
> > > But this only tests if the current outputformat is defined correctly ...
> > > Does anyone know if we can use the mapObj.save() function to create
> > > mapfiles with multiple OUTPUTFORMAT definitions and if not anyone know
> > > where the save() function's defined and if its easy to extend it to do
> > > this?
> > > thanks heaps
> > > shoaib
> > > http://nomad-labs.com
