Mapscript mapObj.save() to write out multiple outputformats
Frank Warmerdam
warmerdam at POBOX.COM
Mon Jul 3 05:52:51 EDT 2006
Shoaib Burq wrote:
> Hi all
> we are trying to create a mapfile on the fly and need to add multiple
> outputformats to the mapfile. we can use the
> appendOutputFormat(new_OF) in python-mapscript. However when using the
> mapObj.save(mymapfile.map) to write our map object to file, it only
> writes-out the last format appened.
> The only relavent code i found was in:
> mapserver/mapscript/python/tests/cases/outputformattest.py
> But this only tests if the current outputformat is defined correctly ...
> Does anyone know if we can use the mapObj.save() function to create
> mapfiles with multiple OUTPUTFORMAT definitions and if not anyone know
> where the save() function's defined and if its easy to extend it to do
> this?
Shoaib,
I think this is a bug. If you could submit a bugzilla entry on this and
ensure it is assigned to me I'll look into fixing it. At least in 4.9.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
