Image tilling
Fawcett, David
David.Fawcett at STATE.MN.US
Mon Jul 3 09:02:32 EDT 2006
Ryan,
There may be additional issues, but if you are not explicitly calling
this layer by name in the URL or post request, you need to set the layer
status to DEFAULT to make the layer visible.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Ryan Ollerenshaw
Sent: Friday, June 30, 2006 3:10 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Image tilling
What I am trying to do is to georeference aerial photos of a large area,
eventually the entire earth. So what I need is to be able to specify
the lat/long of each photo (which I have) using only the lat/long
coordinate system. I would like the user to be able to specify a
bounding box (lat/long) for a given area then have my mapserver return
all the available images for that given area. Currently I think that I
can use:
thm_dir_N-30_180.tiff
To georeference all of my photos, then:
gdaltindex thm_dir.shp *.tif
To create a shape file with an index of all the photos, then I can
specify my layer in the mapfile as:
LAYER
NAME "tileindex"
STATUS ON
TILEINDEX "thm_dir.shp"
TILEITEM "Location"
TYPE RASTER
END
But when I display this layer in MapServer I get a blank image, and
when I try to view the shape file in ArcMap I can see my tiles but they
are just displayed as blank polygons with no images. I think that my
problem is incorrectly specifying the EXTENT in the map file, but i am
not sure what i should put if i want my tiles to eventually cover then
entire world.
Thanks,
-Ryan
Here is my entire map file incase that helps any:
NAME WMSDEMO
STATUS ON
SIZE 500 400
#EXTENT 0 0 2800 2800
#EXTENT -180 -90 180 90
EXTENT -9200000 -912631 3072800 3840000
#UNITS METERS
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
WEB
TEMPLATE test_template.html
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
WMS_TITLE "WMS test mapserver"
WMS_ACCESSCONSTRAINTS "none"
#WMS_ONLINERESOURCE "http://neuron/cgi-bin/mapserv?map=display.map&"
WMS_SRS "EPSG:4326" #"AUTO:42003"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER # Shaded Relief Raster
NAME test_layer
DATA bath_mapserver.tif
STATUS ON
TYPE RASTER
END
LAYER
NAME "hpool"
STATUS ON
#DATA "thm_dir_00_030.tiff"
#TILEITEM "Location"
TYPE RASTER
END
END # of map file
