nothing shows up! no image or error?
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Thu Jul 6 17:24:22 EDT 2006
Obviously your EXTENT and your layer projections do not match. Either use EXTENT values in epsg:26914 (you can check suitable values for your layer with ogrinfo). However, if you want to reproject the data and have output in lat/lon then you must set projection for MAP level as well. EXTENT tells the map area in output projection.
Regards,
-Jukka-
-----Original Message-----
From: UMN MapServer Users List on behalf of Albert Anderson
Sent: Thu 6.7.2006 17:22
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] nothing shows up! no image or error?
I am still having problem with not seeing anything. Here is my code again for the map file.
#This is Richland County Map Server
NAME "Richland"
SIZE 800 600
IMAGECOLOR 255 255 255
IMAGETYPE JPEG
SHAPEPATH "/home/mapdata/"
EXTENT -97.134375 46.044375 -96.534375 46.494375
WEB
TEMPLATE '/var/www/htdocs/richland.html'
IMAGEPATH '/var/www/htdocs/tmp'
IMAGEURL '/tmp/'
END
LAYER
NAME "Richland"
STATUS default
TYPE polygon
DATA "RICH_bndy"
PROJECTION "init=epsg:26914"
END
CLASS
STYLE
COLOR 0 0 0
END
END
END
END
Is my code right? Can you help me?
Thanks,
Albert
"Fawcett, David" <David.Fawcett at state.mn.us> wrote:Message Albert,
Projection in MapServer isn't handled with an external file, like in ArcMap. It is done in the map file. Take a look at the Mapfile documentation to see how to do projection.
http://mapserver.gis.umn.edu/docs/reference/mapfile/projection/view
You need to define a projection block in the MAP block of the map file, this is set to the projection that you want your data output in.
You would then define a projection block in each layer, this is set to the projection that the original data for that layer is in. It is easiest to use epsg codes, look at example 2 in the link above.
The epsg code for UTM zone 14N nad83 is 26914 and 4326 can be used for you lat/long data.
David.
From: Albert Anderson [mailto:bart_doggers at yahoo.com]
Sent: Wednesday, July 05, 2006 11:58 AM
To: Fawcett, David; MAPSERVER-USERS at lists.umn.edu
Subject: RE: [UMN_MAPSERVER-USERS] nothing shows up! no image or error?
I was using a projection file UTM Zone 14n Nad_83. Then I switch to an unprojective file and I saw my data show up. What would be the first best step for setting a projection file?
Thanks
Albert
"Fawcett, David" <David.Fawcett at state.mn.us> wrote: You may want to take a look at your extent.
Do you really intend to show a primarily empty stretch of the northern Atlantic Ocean (apologies to Canary Islanders...)?
You are telling MapServer that your map area is contained within a box from 50 deg. west longitude to 10 deg. west longitude and 20 to 90 degrees north latitude. If the name of your mapfile relates to the data, I am guessing that Richland County isn't in this box.
Use ogrinfo or a desktop GIS app to look at the extent of your data. Also, the extent needs to be in the units of the spatial reference system that your data is in.
David.
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Albert Anderson
Sent: Wednesday, July 05, 2006 10:10 AM
Subject: [UMN_MAPSERVER-USERS] nothing shows up! no image or error?
I am making my own map file. It looks all right but when I click the button it doesnt show an image or any kind of errors.
Here is my map code.
NAME "Richland"
SIZE 100 100
IMAGETYPE JPEG
EXTENT -50.00 20.00 -10.00 90.00
WEB
IMAGEURL '/tmp/'
END
LAYER
NAME "Richland"
STATUS default
TYPE polygon
DATA "RICH_bndy"
CLASS
STYLE
COLOR 0 0 0
END
END
END
END
here is my html code
<html>
<head><title>Richland County MapServer</title></head>
<body>
<form method=post action="/cgi-bin/mapserv">
<input type="submit" value="Click Me"
<input type="hidden" name="map"
value="/home/mapdata/richland.map">
<input type="hidden" name="map_web_imagepath"
value="/var/www/htdocs/tmp/">
</form>
<table border="1" width="400" height="400">
<tr>
<td align="center" valign="top">
<IMG SRC="[img]" width="400" height="400" border="1">
</td>
</tr>
</table>
</body>
</html>
I really dont know whats could be wrong. Maybe the extent of it? Can anyone help me?
Thanks,
Albert
How low will we go? Check out Yahoo! Messengerâ?Ts low PC-to-Phone call rates.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
