msDrawShape(): General error message. Unknown layer type
Henrik Stutz
Henrik.Stutz at FIMR.FI
Mon Jul 24 03:54:36 EDT 2006
Hi All,
I'm trying to set up raster querying on Mapserver 4.8.3. When
"mode=query" is enabled the following error occurs: "msDrawShape():
General error message. Unknown layer type".
Does anyone has an idea how to solve this problem?
Cheers and thanks,
Henrik
http://localhost/cgi-bin/mapserv_483?map=%2Fvar%2Fwww%2Fhtml%2Fperl_test
%2FBalticBoundary.map&map_web_imagepath=%2Fvar%2Fwww%2Fhtml%2Ftmp%
2F&map_web_imageurl=%2Ftmp%2F&savequery=true&imgext=245990.225000
+6427447.275000+4190855.225000
+10372312.275000&layer=chlaYYMMDDsat&program=%2Fcgi-bin%
2Fmapserv_483&img.x=168&img.y=124&zoomsize=3&mode=query
-------template.html-----------
<html>
<head>
<title>MapServer </title>
</head>
<form method=GET action=[program]><input type="hidden" name="map"
value="[map]">
<input type="hidden" name="map_web_imagepath"
value="[map_web_imagepath]">
<input type="hidden" name="map_web_imageurl"
value="[map_web_imageurl]">
<input type="hidden" name="savequery" value="true">
<input type="hidden" name="imgxy" value="299.5 299.5">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="layer" value="chlaYYMMDDsat" >
<input type="hidden" name="program" value="[program]">
Select quad<input type="radio" name="mode" value="query"><br>
</form>
</body>
</html>
----------------mapfile----------
NAME Boundary
STATUS ON
SIZE 600 600
WEB
IMAGEPATH "/var/www/html/perl_test/tmp/"
IMAGEURL "/tmp/"
TEMPLATE "template.html"
END
EXTENT 252565 6.8044e+06 4.19743e+06 9.98221e+06
UNITS kilometers
IMAGECOLOR 255 255 255
IMAGETYPE png
FONTSET "/home/henriks/mapserver/mapserver-4.8.3/tests/fonts.txt"
REFERENCE
EXTENT 254657 6.80479e+06 4.19846e+06 9.98175e+06
IMAGE "./reference.png"
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
QUERYMAP
STATUS ON
STYLE SELECTED
END
LAYER
NAME baltic_mask
TYPE RASTER
STATUS DEFAULT
DATA /opt/MODIS/GIS/2006g6/BalticMerc07/PERMANENT/cellhd/baltic_mask
TOLERANCE 3
TOLERANCEUNITS PIXELS
CLASS
NAME "Baltic_mask"
TEMPLATE quadtemplate.html
LABEL
TYPE truetype
FONT Vera
SIZE 8
ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 212 212 212
PARTIALS OFF
END
END
END
LAYER
NAME chlaYYMMDDsat
TYPE RASTER
STATUS OFF
TRANSPARENCY 50
DATA /opt/MODIS/GIS/2006g6/BalticMerc/T/cellhd/chlasat
TOLERANCE 3
CLASS
NAME "Chlorophyll-a"
END
END
------quadtemplate.html----------------------------
<html>
<head>
<title>MapServer Test</title>
</head>
<body bgcolor="#ffffff">
<br>
<font size=+2 face=arial,helvetica>You selected the
<b>[TILE_NAME]</b> Quadrangle</font>
<p>
<img src="[img]">
<tr>
<td>[lrn]</td>
<td>[PIN]</td>
</tr>
<p>
<a href="javascript:history.back()">return to map...</a>
</body>
</html>
