shp2pgsql | psql error: fseek(...) failed on DBF file.
Manfred Meier
m.meier at SPIEKERMANN.DE
Tue Jul 25 02:49:26 EDT 2006
Hello,
I hope this is not trivial:
- does dbfdump and dbfdump --info give you correct info about yout dbf file?
- i had some time ago seg faults with shp2img because my dbf file had
less records than i had shapes in the shapefile. it could be that
shp2pgsql does not generate seg faults and instead makes a wrong fseek.
Manfred
P Kishor schrieb:
> while running
> shp2pgsql foo foo | psql
> # shp2pgsql foo foo | psql -d foo
> I get a bunch of...
> fseek(-2045813584) failed on DBF file.
> before I Ctrl-C the operation. Any ideas why, and how I can correct it?
> By the way, I get the same errors even when I two-step the operation
> and try to create the interim sql file. What can I look for in my DBF
> file to try and correct it?
> Many thanks,
