[UNCLASSIFIED]RE: [UMN_MAPSERVER-USERS] minimal Linux version req
uired.
Antti Roppola
Antti.Roppola at BRS.GOV.AU
Tue Jul 25 22:22:35 EDT 2006
Frank wrote:
> J-G Hasbani wrote:
>> Hello everybody.
>> I am considering to buy an old server in order to run MapServer.
>> The server has the following characteristics:
>> *Red Hat Linus 6.0 for x86 compatible
>You might be a bit wary about security bugs in older versions of Linux like this though. Not that I'm specifically aware of >any.
I would most certainly consider re-installing a more recent operating
system from scratch; especially if there's any uncertainty about what
software is and isn't on the server, and how current (secure) it is.
Ubuntu is free and easy to install, however you may have access to Red Hat
knowledgable people. As a plus, you will have a means for getting system
updates (not sure what the support status of Red Hat 6 is), and the confidence
that you can rebuild the server from first principles if the hard disk ever dies.
Note that some dedicated server hardware can use expensive or difficult to
come by components. I had a server that was not worth fixing because one
U-SCSI disk in the array cost more than I had paid for the entire server.
If you want to tinker with Mapserver, pretty much any old PC will do (and
probably be a lot quieter than a tower case crammed full of high speed disk).
Antti
IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
