Map File Problem?
    M.L. Jackson
    mljacks2 at HOTMAIL.COM
    Fri Jul 28 08:40:57 PDT 2006
The thing is.......the errors occur at random.  If the errors weren't
related to some central problem, then the same error should keep occuring
until I fix it before any other errors are displayed.  Instead each time the
server is restarted and the application is run a new error supposedly in the
map file is displayed.
>From: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>Reply-To: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Map File Problem?
>Date: Fri, 28 Jul 2006 10:55:45 -0400
>I'm not sure about your random problem...but you might want to check the
>errors section of the mapserver documentation page, and battle those errors
>one by one: http://mapserver.gis.umn.edu/docs/error
>jeff
>M.L. Jackson wrote:
>>Hi.  I am running mapserver 4.6.0-beta1 with Java Mapscript on Tomcat.
>>While working on my project, I have encountered a weird series of errors.
>>Everytime I restart the server and try to run my application, I get an
>>error indicating what appears to be any random line in the map file.
>>Most of the time the errors generated make absolutely no sense.  Among the
>>errors generated are "projection not named" and  "major axis or radius = 0
>>or not given". The other errors are generally any line number with a piece
>>of the map file indicated.  Thanks for your replies.
>>_________________________________________________________________
>Jeff McKenna
>DM Solutions Group Inc.
>http://www.dmsolutions.ca
Dont just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
More information about the MapServer-users
