Map File Problem?
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Fri Jul 28 11:46:39 EDT 2006
have u tried using the shp2img utility, to see if your mapfile is ok?
I'd first make sure your mapfile is fine, then worry about your application.
jeff
M.L. Jackson wrote:
> The thing is.......the errors occur at random. If the errors weren't
> related to some central problem, then the same error should keep
> occuring until I fix it before any other errors are displayed. Instead
> each time the server is restarted and the application is run a new error
> supposedly in the map file is displayed.
>> From: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>> Reply-To: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] Map File Problem?
>> Date: Fri, 28 Jul 2006 10:55:45 -0400
>> I'm not sure about your random problem...but you might want to check
>> the errors section of the mapserver documentation page, and battle
>> those errors one by one: http://mapserver.gis.umn.edu/docs/error
>> jeff
>> M.L. Jackson wrote:
>>> Hi. I am running mapserver 4.6.0-beta1 with Java Mapscript on
>>> Tomcat. While working on my project, I have encountered a weird
>>> series of errors. Everytime I restart the server and try to run my
>>> application, I get an error indicating what appears to be any random
>>> line in the map file. Most of the time the errors generated make
>>> absolutely no sense. Among the errors generated are "projection not
>>> named" and "major axis or radius = 0 or not given". The other errors
>>> are generally any line number with a piece of the map file
>>> indicated. Thanks for your replies.
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
