Map File Problem?
M.L. Jackson
mljacks2 at HOTMAIL.COM
Fri Jul 28 12:59:47 EDT 2006
Where is the shp2img utility? Does it come with mapserver or do you have to
download it? Sorry for the newbie questions but thanks for your help.
>From: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>Reply-To: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Map File Problem?
>Date: Fri, 28 Jul 2006 11:46:39 -0400
>have u tried using the shp2img utility, to see if your mapfile is ok? I'd
>first make sure your mapfile is fine, then worry about your application.
>jeff
>M.L. Jackson wrote:
>>The thing is.......the errors occur at random. If the errors weren't
>>related to some central problem, then the same error should keep occuring
>>until I fix it before any other errors are displayed. Instead each time
>>the server is restarted and the application is run a new error supposedly
>>in the map file is displayed.
>>>Date: Fri, 28 Jul 2006 10:55:45 -0400
>>>I'm not sure about your random problem...but you might want to check the
>>>errors section of the mapserver documentation page, and battle those
>>>errors one by one: http://mapserver.gis.umn.edu/docs/error
>>>jeff
>>>M.L. Jackson wrote:
>>>>Hi. I am running mapserver 4.6.0-beta1 with Java Mapscript on Tomcat.
>>>>While working on my project, I have encountered a weird series of
>>>>errors. Everytime I restart the server and try to run my application, I
>>>>get an error indicating what appears to be any random line in the map
>>>>file. Most of the time the errors generated make absolutely no sense.
>>>>Among the errors generated are "projection not named" and "major axis
>>>>or radius = 0 or not given". The other errors are generally any line
>>>>number with a piece of the map file indicated. Thanks for your replies.
>Jeff McKenna
>DM Solutions Group Inc.
>http://www.dmsolutions.ca
_________________________________________________________________
Dont just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
