PHP as CGI not working / Premature end of script headers
Volkan Ulukut
vulukut at TESCILTURK.COM
Tue Jun 6 04:51:55 EDT 2006
Greetings,
I'm trying to get mapscript working but i get the error that i should run
php as cgi. I followed the instructions on
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI. Since I had
preloaded php as an apache DSO and wish to only run mapscript as a CGI I
added
Action phtml-script /cgi/php
AddHandler phtml-script .phtml
And
<Directory /path/to/mapscript/cgi>
Options ExecCGI FollowSymLinks
</Directory>
To httpd.conf
Created cgi directory under mapscript files
#mkdir cgi
#chgrp nobody ./cgi
#chmod 750 ./cgi
Then i created a symbolic link into cgi directory
ln -s /usr/local/bin/php /path/to/mapscript/cgi/php
Then i've restarted apache. And tried to navigate to my test page which is
at /path/to/mapscript/test.phtml
It's content is:
<HTML>
<BODY>
<?php
if (PHP_OS == "WINNT" || PHP_OS == "WIN32")
dl("php_mapscript.dll");
else
dl("php_mapscript.so");
phpinfo();
</BODY>
</HTML>
But only thing i get is 500 Internal Server Error. When i check the apache
web logs i see:
Premature end of script headers: /path/to/mapscript/cgi/php
I try to run the script on shell using:
/usr/local/bin/php -e /path/to/mapscript/test.phtml
And i get the desired result.
But on the browser i can't get any output.
Any thought about that?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060606/a2b77317/attachment.html
