raster image preprocessing problem.
Travis Kirstine GIS Tech
tkirstine at JDBARNES.COM
Tue Jun 6 08:14:59 EDT 2006
Zhonghai,
My guess is that both the gdal_warp and gdal_merge utilities use the pusedo
colour table of the first image and apply that table to all other images, I
would try converting the gif to RGB geotiffs using the pct2rgb gdal utility
then go through your processing steps(warping and merging) then convert the
images back to 8bit GIFs. I hope this helps
Travis
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Zhonghai Wang
Sent: Tuesday, June 06, 2006 6:35 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] raster image preprocessing problem.
Hi there,
I have a couple of GIFs with wld files, but the original Projection is not
the one I want, I tried to use the Proj4 to reproject them on-the-fly, but
it takes really long to perform the map request, therefore I tried to
preprocess the images with GDAL tools, but I've got some problems here:
1. problem with gdalwarp: trying to mosaic the images into one output
file, but only the first image has the correct image color, the other images
are rendered with strange colors, is this a common problem if using gdalwarp
to mosaic images?
2.problem with gdal_merge.py: after trying the gdalwarp command, I've
tried the gdal_merge.py command to merge all the images together with
the -pct parameter, unfortunately, the merged image is the same as the first
try. is it possible to merge images using the command with the correct color
table?
BTW: I can not use the gdal_translate command, since there are gaps
between the reprojected images.
thanks for your info.
zhonghai
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060606/38bb24e0/attachment.html
