draw a line with arrows indicating direction of tavel...
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Jun 9 17:06:44 EDT 2006
John,
Set the gap to a negative number in your symbol definition.
-SteveW
John Cole wrote:
> Hello, I'm trying to render a line and show the direction of travel
> (the points in the lines are in the proper order). Attempting to use
> a true type symbol, and come to find it is working as designed :-)
> http://mapserver.gis.umn.edu/docs/howto/cartosymbols/#signatures-of-type-tru
> etype
> So, how do I go about rendering an arrow at regular intervals along a
> line and have them follow the direction of the points in the line?
> Thanks,
> John Cole This email and any files transmitted with it are
> confidential and intended solely for the use of the individual or
> entity to whom they are addressed. If you have received this email in
> error please notify the sender. This message contains confidential
> information and is intended only for the individual named. If you are
> not the named addressee you should not disseminate, distribute or
> copy this e-mail.
