Problem with the mailinglist
Christian Wilmes
C.Wilmes at GMX.DE
Mon Jun 12 03:59:45 EDT 2006
>sorry, you are right, of course it was the 9th of June. I can't see any regularity for the delay, it just seems to be chance.
So where do I have to search the problem? It seems nobody else have the same problems, so could it be a problem of my mail-provider (gmx.de)?
This message was sent on Monday the 12th of june at 09:53am german time.
Best Regards
Christian
-------- Original-Nachricht --------
> Datum: Sat, 10 Jun 2006 08:39:08 +0200
> Von: Manfred Meier <m.meier at SPIEKERMANN.DE>
> An: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re: [UMN_MAPSERVER-USERS] Problem with the mailinglist
> Hi,
> in my mailbox this message showed up on Sat, 10. June 2006 at about
> 08:35 German time.
> Friday was the 9th of June not the 8th. Was that a typo?
> Manfred Meier
> Christian Wilmes schrieb:
> > Hi all,
> > I've got some problems with this mailinglist. If I sent a mail to the
> list it takes hours or even days until it is in the list. If I try to sent
> a mail directly from the mailinglist homepage, after a few seconds I get
> the following mail:
> > Rejected posting to MAPSERVER-USERS at LISTS.UMN.EDU
> > Your message is being returned to you unprocessed because it appears
> to have already been distributed to the MAPSERVER-USERS list. That is, a
> message with identical text (but possibly with different mail headers)
> has been posted to the list recently, either by you or by someone
> else.
> If you have reason to resend this message to the list (for instance
> because you have been notified of a hardware failure with loss of data),
> please alter the text of the message in some way and resend it to the
> list. Note that altering the "Subject:" line or adding blank lines at
> the
> top or bottom of the message is not sufficient; you should instead add
> a
> sentence or two at the top explaining why you are
> > resending the message, so that the other subscribers understand why
> they are getting two copies of the same message.
> > > Because of these things it happens in the last time, that I was
> sending
> a mail more than one time, sorry for that!
> > > I hope someone who is responsible for the mailinglist will read this
> mail and is probatly able to help me.
> > This mail for example I will send at on Friday 08.06.2006 at 11:20am
> German time....wonder how long it will take this time until the mail is in
> the list.
> > Best Regards
> > Christian
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
