oracle spatial
Daniel Goetz
madprof at GMX.CH
Mon Jun 12 04:54:26 PDT 2006
I have the ms4w installed on my computer and I want to map geodata, lying in a oracle spatial database on a server in the intranet, via umn mapserver. Therefor I enabled OGR-OCI support described in the readme-file of the ms4w-package (I "installed" 10g oracle instant client on my computer, set set windows environmet variable PATH and did the described .dll swapping).
Then I tested, whether OGR now supports the OCI with ogrinfo. Therefor I had to modify the syntax a littel bit to get information: I wrote "ogrinfo "OCI:username/password at host:port/service_name" instead of described on the ogr-site/oracle spatial "OCI:username/password at service_name". The result was that ogrinfo listed me the relevant tables that contain geometric data.
Then I tried to map the data via mapserver. Therefor I wrote the following .map-file (therefor I correspond to the example given in the "Vector Data Access-Reference-Guide" on the mapserver-site):
MAP
NAME "Oracle"
EXTENT 426666.49 466058.21 448321.44 490754.58
SIZE 1400 1800
SHAPEPATH "/ms4w/Apache/htdocs/raster/daten"
IMAGETYPE PNG
IMAGECOLOR 255 255 255
UNITS METERS
STATUS ON
CONFIG "GDAL_DRIVER_PATH" "C:/ms4w/gdalplugins"
WEB
IMAGEPATH "c:\ms4w\Apache\htdocs\raster\tmp\"
IMAGEURL "/raster/tmp/"
TEMPLATE "test_template.html"
END
LAYER
CONNECTIONTYPE OGR
CONNECTION "OCI:username/password at service_name"
DATA "RWG_TBS"
NAME "RWG_TBS"
TYPE POLYGON
STATUS ON
CLASS
NAME "Flaeche"
STYLE
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
END
END
END
The template I wrote therefor is very simple:
<html>
<head>
<title>Erstes Beispiel zum UMN Mapserver</title>
</head>
<body>
Mapserver-Version auslesen:<br><br>[version]<br><br><br>
Karte einbetten:<br><br>
<img src="[img]"><br>
</body>
</html>
And I tried to start mapping by writing the following in my browser:
http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/raster/test_os_ogr.map&layers=all&
The result was, that mapserver brought the error-message:
"mapserv(): Web application error. No template provided. "
Then I tested some other mapserver-test-projects, for whom I know that they have worked properly on my computer before the mentioned .dll swapping for OGR-OCI support. The result was the same:
So I have three questions:
How should mapserver know where the database is located without giving him any information about the host-address and the port-number. Where can I provide this information for the mapserver. In the case of ogrinfo I did this by writing "OCI:username/password at host:port/service_name". In the .mpa-file example in the "Vector-Data-Reference-Guide" they say under CONECTION you should type "OCI:username/password at service_name". Where is the information about the location of the database?
Second questions is: Is anything wrong with my .map-file, html-template or the starting-command in the web-browser?
Third: And why do the other mapserver projects, I tested before .dll swapping (for OGR-COI support), work anymore. Why do I always get the error-message "mapserv(): Web application error. No template provided." although I changed nothing on the .map-files, the template nor the command.
I would be very pleased and hayppy and thankful if anybody would help me on my problem. This would really be very nice. Thank you so much for your endeavors.
Regards
Daniel
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
More information about the MapServer-users
