Problem with the mailinglist
Pericles S. Nacionales
naci0002 at UMN.EDU
Mon Jun 12 15:05:57 EDT 2006
Christian,
If you or anyone run into this problem again please send mailadm at umn.edu
an e-mail outlining the problem (it is their request). Also, please CC
me on that e-mail so I can keep track of the issues. No one is exactly
sure how this issue is propagated but it's happened to a few (you're the
fourth person I know who has gotten this message). Maybe it has to do
with the UMN's mail server...
Thanks,
Perry
Christian Wilmes wrote:
>>> That couldn't be the problem, I haven't choose that option. But the last time it seems to work. I get my own message at 9:59.
> So hoping I've got luck again and this message will be in the list in a few minutes too.
> Mo 11:02 am German Time.
> -------- Original-Nachricht --------
>> Datum: Mon, 12 Jun 2006 10:08:43 +0200
>> Von: Manfred Meier <m.meier at SPIEKERMANN.DE>
>> An: MAPSERVER-USERS at LISTS.UMN.EDU
>> Betreff: Re: [UMN_MAPSERVER-USERS] Problem with the mailinglist
> Hi,
>> I received this message on Monday 12, 10:00 German time. Not bad!
>> A long time ago, when I did subscribe to the list there was an option to
>> get all mails bundled once a day. Can this be the problem in your case?
>> Greetings
>> Manfred Meier
>> Christian Wilmes schrieb:
>>>> sorry, you are right, of course it was the 9th of June. I can't see any
>> regularity for the delay, it just seems to be chance.
>>>> So where do I have to search the problem? It seems nobody else have
>> the
>> same problems, so could it be a problem of my mail-provider (gmx.de)?
>>> This message was sent on Monday the 12th of june at 09:53am german time.
>>> Best Regards
>>> Christian
>>>> Datum: Sat, 10 Jun 2006 08:39:08 +0200
> Hi,
>>>> in my mailbox this message showed up on Sat, 10. June 2006 at about
>>>> 08:35 German time.
>>>> Friday was the 9th of June not the 8th. Was that a typo?
>>>> Manfred Meier
>>>>> Hi all,
>>>>> I've got some problems with this mailinglist. If I sent a mail to the
>>>> list it takes hours or even days until it is in the list. If I try to
>> sent
>>>> a mail directly from the mailinglist homepage, after a few seconds I get
>>>> the following mail:
>>>>> Rejected posting to MAPSERVER-USERS at LISTS.UMN.EDU
>>>>> Your message is being returned to you unprocessed because it appears
>>>> to have already been distributed to the MAPSERVER-USERS list. That is,
>> a
>>>> message with identical text (but possibly with different mail headers)
>>>> has been posted to the list recently, either by you or by someone
>>>> else.
>>>> If you have reason to resend this message to the list (for instance
>>>> because you have been notified of a hardware failure with loss of data),
>>>> please alter the text of the message in some way and resend it to the
>>>> list. Note that altering the "Subject:" line or adding blank lines at
>>>> the
>>>> top or bottom of the message is not sufficient; you should instead add
>>>> a
>>>> sentence or two at the top explaining why you are
>>>>> resending the message, so that the other subscribers understand why
>>>> they are getting two copies of the same message.
>>>>>> Because of these things it happens in the last time, that I was
>>>> sending
>>>> a mail more than one time, sorry for that!
>>>>>> I hope someone who is responsible for the mailinglist will read this
>>>> mail and is probatly able to help me.
>>>>> This mail for example I will send at on Friday 08.06.2006 at 11:20am
>>>> German time....wonder how long it will take this time until the mail is
>> in
>>>> the list.
>>>>> Best Regards
>>>>> Christian
