css in template file
Micha Silver micha at ARAVA.CO.IL
Tue Jun 13 03:24:19 PDT 2006
Can I use a css style sheet in a template file?
I have a css file set up, and if I open the template (html) file
directly, the styles are correctly applied. However when I run a map
file from the mapserv cgi (with the template defined in the map file) I
see my map, and all the html tags but the styles are NOT applied.
What have I done wrong?
Thanks,
Micha
More information about the MapServer-users mailing list
