Anti Alias Problem
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Jun 14 04:12:06 EDT 2006
On 6/14/06, Thomas Hammerlund <tom at maplink.jp> wrote:
> Thank you for your reply Steve.
> I'm running mapserver 4.8.3 and outputting jpegs via the gdal/jpeg driver.
> I'm using the gdal driver because the gd/jpeg driver output progressive
> encoded jpegs(which i couldn't use).
> Example layer:
> LAYER
> NAME l_koku_u
> STATUS ON
> TILEINDEX "ixs/shb/50000/l_koku_u_ix"
> TILEITEM "location"
> TYPE LINE
> CLASSITEM Code
> CLASS
> MAXSCALE 337000
> MINSCALE 85001
> Name style1
> EXPRESSION 'l_bbbcd'
> STYLE
> COLOR 240 184 53
> WIDTH 1
> #ANTIALIAS TRUE
> END
> END
> END
> I'm creating my image using perl mapscript. my mistake, the problem is not
> with the fonts but with the lines. when I turn style antialiasing on for my
> line layers perl throws an internal server error with no error message from
> mapserver (or perl).
> The outputformat in my mapfile looks like this:
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "GDAL/JPEG"
> MIMETYPE "image/jpeg"
> IMAGEMODE RGB
> FORMATOPTION "QUALITY=100"
> EXTENSION "jpg"
> END
> Which antialias patch are you referring to?
This one (against gd-2.0.33):
*** gd.c.orig Wed Jun 14 10:06:22 2006
--- gd.c Mon Jun 12 12:05:28 2006
*** 3032,3037 ****
--- 3032,3040 ----
static void gdImageSetAAPixelColor(gdImagePtr im, int x, int y, int
color, int t)
int dr,dg,db,p,r,g,b;
+ if(x<0||y<0||x>=im->sx||y>=im->sy) {
+ return;
p = gdImageGetPixel(im,x,y);
/* TBB: we have to implement the dont_blend stuff to provide
the full feature set of the old implementation */
or this one:
http://lists.maptools.org/pipermail/ka-map-users/2006-March/001069.html
The latter is probably better, as it uses a gd macro...
HTH,
Umberto
> Thank you again,
> Tom
> ----- Original Message -----
> From: "Steve Lime" <Steve.Lime at dnr.state.mn.us>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>; <tom at MAPLINK.JP>
> Sent: Wednesday, June 14, 2006 2:56 PM
> Subject: Re: [UMN_MAPSERVER-USERS] Anti Alias Problem
> > Hmmm... I'm suprised turning off style antialiasing would impact font
> > antialiasing.
> > They are totally unrelated.
> > I guess we need a bit more information. What version of MapServer? Has the
> > GD
> > anti-aliasing patch been applied? What output image format?
> > Steve
> >>>> Thomas Hammerlund <tom at MAPLINK.JP> 06/13/06 1:03 AM >>>
> > Hi Everyone,
> > I've been looking for a solution to this, but haven't been successful so
> > far
> > so I'm hoping someone can help.
> > I'm using Fedora 5, and everything I need is working great. The problem
> > is
> > that when I try the same data set on Fedora 4 or Red Hat Advanced Server,
> > anti alias doesn't work. The problem can be resolved by commenting out
> > the
> > antialias line, but then it makes my font and lines look too choppy. Has
> > anyone seen this? Does anyone know if this is a Linux or a Mapserver
> > problem?
> > Thank you for your help,
> > Tom
