Compile MapSevrer with VS2005 (MapServer BuiltKit source code)
Zhonghai Wang
zhonghaiw at GMAIL.COM
Wed Jun 14 16:52:16 EDT 2006
Hi Tamas,
I really appreciate your help.
and in my case, I uncomment also several options, but for my application
Oracle Spatial support is needed, so I use the latest version BuiltKit
from Howard Butler. I will try to compile all the needed libraries with
VS2005.
BTW: to compile CSharp/MapScript with MapServer, what I need to do is to
umcomment the DOTNET option in the nmake.opt file in the
mapserver-4.8.3folder, which is:
# .NET/C# MapScript
# .NET will of course only work with MSVC 7.0 and 7.1. Also note that
# you will definitely want USE_THREAD defined.
DOT_NET = YES
is that right? but the MSVC 7.0 and 7.1.seems for VS2003.
thank you very much.
zhonghai
On 6/14/06, Tamas Szekeres <szekerest at gmail.com> wrote:
> Zhonghai,
> The buildkit was compiled originally with VS2003, compiling with VS2005 is
> not so straightforward.
> When compiling gdal you probably link against several libs compiled with
> VS2003 previously so you should compile those libraries with VS2005 first.
> See nmake.opt and search for the .lib references to locate those
> libraries.
> I suggest to disable the libraries not really needed for your application.
> (Even with mapserver and gdal)
> I cannot confirm if all of the libraries could be enabled easily. In my
> application ORACLE, SDE, XERCES, GEOS, ECW were disabled. (however these are
> enabled by default).
> However some folks might have gone forward with the libraries mentioned
> previously as well.
> Best Regards,
> Tamas Szekeres
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
> Behalf Of *Zhonghai Wang
> *Sent:* Wednesday, June 14, 2006 5:33 PM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* [UMN_MAPSERVER-USERS] Compile MapSevrer with VS2005 (MapServer
> hi guys,
> I am trying to compile MapServer with VS2005 now, and I've struggle with
> it for almost one day, but I am still in the dark...the following is done
> for the compilation, and any ideas from you will be so helpful.
> 1.source code download: -- the MapServer BuildKit from Howard Butler
> http://hobu.stat.iastate.edu/mapserver/build_output/
> and I have downloaded the latest package version "
> mapserver-4.8.3-2-msvc71-buildk-kit.zip"
> 2.and I follow the compilation guide here:
> http://www.nabble.com/Windows-build-kit-for-MSVC-7.1-t1143108.html#a2997024
> to compile MapServer, according to this doc, I should at first compile
> the GDAL package, and then come to the MapServer package. But when I am
> trying to compile the GDAL
> package under VS2005 command prompt with the command "nmake /f
> makefile.vc", there are some error messages appears, the scenario is:
> *C:\buildkit\gdal-1.3.2>nmake /f makefile.vc clean
> *and here come the error messages, I paste only the first one here,
> because I think if I fix this problem, the other error may be fixed at the
> same time:
> *msvcprt.lib(MSVCP80.dll) : error LNK2005: "class
> std::basic_string<char,struct s
> *td::char_traits<char>,class std::allocator<char> > __cdecl
> std::operator+<char,s
> *truct std::char_traits<char>,class std::allocator<char> >(class
> std::basic_strin
> *g<char,struct std::char_traits<char>,class std::allocator<char> > const
> &,char c
> *onst *)" (??$?HDU?$char_traits at D@std@@V?$allocator at D@1@@std@@YA?AV?$basic_string
> *@DU?$char_traits at D@std@@V?$allocator at D@2@@0 at ABV10@PBD at Z<*@DU?$char_traits at D@std@@V?$allocator at D@2@@0 at ABV10@PBD at Z>)
> already defined in geos
> *.lib(WKTReader.obj)
> Because I want to use CSharp/MapScript under the .NET FW 2.0, and I've
> also got some info from the Doc:http://mapserver.gis.umn.edu/docs/howto/mapscriptcscompile
> , it says that I should compile MapServer and the related libraries using
> VS2005 for .NET FW 2.0, I begin with the VS2005 command prompt instead of
> following the compilation guide in the mapserver README.WIN32, which
> gives:
> To build the package using the Makefile.vc and NMAKE:
> - Edit nmake.opt to select (or deselect) optional components of
> the MapServer. Please read the notes below about each component
> before you move ahead with the compilation.
> - Open a DOS prompt window
> - Run the VCVARS32.BAT script to initialize the VC++ environment
> variables. VCVARS32.BAT is automatically generated by the MSVC++
> install procedure and should be located in the BIN sub-directory of
> your MSVC++ installation.
> - Then start the build with:
> nmake /f Makefile.vc
> This will create "mapserv.exe" (the main MapServer CGI program), the
> other command-line utilities, "mapserver.lib" and "libmap.dll" that is
> used by theMapScript modules.
> I am now just wondering if it's possible to compile MapServer and related
> libraries with VS2005, since the MSVCP80.dll can always not be found. Did
> anyone have some experiences about that?
> I would really appreciate it if you give me some HINTS for my compilation.
> zhonghai
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.394 / Virus Database: 268.8.4/364 - Release Date: 2006.06.14.
> No virus found in this outgoing message.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060614/9d316e70/attachment.html
