Character set encoding problem
    Øyvind Eide
    oyvind.eide at MUSPRO.UIO.NO
    Thu Jun 15 05:33:34 PDT 2006
On Thu, Jun 15, 2006 at 01:04:58PM +0200, Erik Baluba wrote:
> Hi Øyvind,
> >I have data in an Oracle 10gR2 database in ISO-8859-1 encoded columns
> >(WE8ISO8859P1) and the names of my geometries appear correctly in a
> >sqlplus search. But on the test mapserver PNG all characters beyond
> >decimal 127 (such as æøå) come out as '?'.
> What is the NLS_LANG setting on the oracle client computer running your
> webserver?  If it is a Norwegian or English Windows the codepage is WIN1252
> and your NLS_LANG would be something like Norwegian_Norway.WE8MSWIN1252. If
> so I see nothing wrong with your setup because character encodings for
> 'æøå' are the same in both ISO-8859-1 and WIN1252. Still, you can try to
> set the ENCODING to CP1252 in your mapping file to see if it helps.
Thank you Eric!
The web server is running on a RHEL linux box. By adding the line
SetEnv NLS_LANG "norwegian_norway.we8iso8859p1"
to the apache conf file (in our case an extra httpd.conf file read
after all the standard ones), the character set was fixed!
Kind regards,
Øyvind Eide
More information about the MapServer-users
