JavaMapscript SIGSEGV
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Thu Jun 15 16:04:42 EDT 2006
Heraldo,
I have tried querying a postgis layer and it works great.
This is the code that I use:
protected List queryLayerByPoint(int i, pointObj queryPoint) {
List results = new ArrayList();
layerObj layer = map.getLayer(i);
if (layer != null && isVisible(layer)) {
if (log.isDebugEnabled()) {
log.debug("Querying layer: " + layer.getName());
if (layer.queryByPoint(map, queryPoint,
mapscript.MS_MULTIPLE, -1) == mapscript.MS_SUCCESS) {
//resultCacheObj resultCache = layer.ggetResultcache();
if (layer.open() == mapscript.MS_SUCCESS) {
//for (int j=0;j<resultCache.getNumresults();j++) {
for (int j = 0; j < layer.getNumResults(); j++) {
log.debug("Layer " + layer.getName() + ",
result number:" + j);
resultCacheMemberObj resultMember = layer.getResult(j);
shapeObj shape = new shapeObj(layer.getType());
layer.getShape(shape,
resultMember.getTileindex(), resultMember.getShapeindex());
if (shape != null) {
Map aResult = getResult(shape, layer);
results.add(aResult);
} else {
log.error("Shape " + j + " is null!");
layer.close();
} else {
log.error("Cannot open layer: " + layer.getName());
} else {
log.info("Query on layer " + layer.getName() + " failed.");
return results;
It is different from yours in that I do not fetch results from the
resultCache and I use layer.getShape instead of getFeature.
Let me know if this fixes your problem.
Regards,
Umberto
On 6/13/06, Rodriguez, Heraldo <hrodriguez at siscat.com.ar> wrote:
> Thank you very much.
> Heraldo G. Rodriguez
> TE 4326-4002 int 255
> Dpto. Desarrollo
> Sistemas Catastrales S.A
> -----Mensaje original-----
> De: Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
> Enviado el: martes, 13 de junio de 2006 10:13
> Para: Rodriguez, Heraldo
> CC: MAPSERVER-USERS at lists.umn.edu
> Asunto: Re: [UMN_MAPSERVER-USERS] JavaMapscript SIGSEGV
> Open an issue on bugzilla (http://mapserver.gis.umn.edu/bugs/) and
> attach the three logs.
> I'll look into this asap.
> Umberto
> > Humberto ,
> > This is the method that is crashing. I am attaching a couple of
> > logs too. (line shapeObj shape = l.getFeature(r.getShapeindex(), -1); )
> > I hope it helps. Thanks
> > public List queryPorPunto(int x, int y) {
> > List lista = new ArrayList();
> > pointObj p = new pointObj(x, y, 0);
> > String row = "";
> > layerObj l = map.getLayerByName("entorno");
> > l.queryByPoint(map, p, mapscriptConstants.MS_MULTIPLE,
> -1);
> > resultCacheObj results = l.getResults();
> > if (results == null)
> > return lista;
> > l.open();
> > for (int i = 0; i < results.getNumresults(); i++)
> > resultCacheMemberObj r =
> > results.getResult(i);
> > shapeObj shape =
> > row = "";
> > for (int j = 0; j < shape.getNumvalues();
> > j++)
> > row = row + "<TD>" +
> > shape.getValue(j) + "</TD>";
> > lista.add(row);
> > l.close();
> > return lista;
> > Dpto. Desarrollo
> > Enviado el: martes, 13 de junio de 2006 3:50
> > Hi,
> > please post the hs_error_* file and the Java program that is causing the
> > crash.
> > Thanks,
> > Umberto
> > On 6/12/06, Rodriguez, Heraldo <hrodriguez at siscat.com.ar> wrote:
> > > Hi guys,
> > > I have started developing with java mapscript and I have the
> > same
> > > problems with the shapeObj class.
> > > Every time I want to create a new shape I get the message
> > > > # An unexpected error has been detected by HotSpot Virtual Machine:
> > > > # SIGSEGV (0xb) at pc=0x00002aaaaae43d5b, pid=23120,
> tid=46912501734144
> > > > # Java VM: Java HotSpot(TM) Client VM (1.4.2_11-b06 mixed mode)
> > > > # Problematic frame:
> > > I am using mapserver 4.8.1 with java 1.4.2_11 version under Debian
> 3.1.
> > > Mapserver Compiling options
> > > ./configure --with-freetype=/usr/local/bin/freetype-config
> > > --with-zlib=/usr/lib --with-png=/usr/local/lib --with-jpeg=/usr/lib
> > > --with-libiconv=/usr/local/lib --with-gd=/usr/local/bin/gdlib-config
> > > --with-pdf=/usr/local/lib --with-proj=/usr/local/lib --with-threads
> > > --with-geos=/usr/local/bin/geos-config
> > --with-ogr=/usr/local/bin/gdal-config
> > > --with-gdal=/usr/local/bin/gdal-config
> > > --with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs --with-wcs
> > > --with-wmsclient --with-curl-config=/usr/local/bin/curl-config
> > > Steps to compile java mapscript
> > > Run make
> > > Make interface (swig version 1.3.29)
> > > Make all
> > > I looked for a solution in google and mapserver documentation without
> > > success. Could you please give me a clue to solve this? Thanks in
> > > advance.
> > > Best regards.
> > > Dpto. Desarrollo
> > > De: Andre Sachs [mailto:asachs at CLUE.CO.ZA]
> > > Enviado el: miércoles, 31 de mayo de 2006 5:16
> > > Para: MAPSERVER-USERS at LISTS.UMN.EDU
> > > On 31 May 2006, at 8:37 AM, Umberto Nicoletti wrote:
> > > > Andre, could you report whether the patch attached to gentoo bugzilla
> > > > works or not?
> > > Hi Umberto,
> > > Sorry for not replying earlier.
> > > The patch works in a 32 intel environment, thanks !
> > > Due to time constraints on my current project I ditched my AMD 64,
> > > Java 1.5 64 bit environment in favour of Intel 32 bit and this has
> > > resolved my problem.
> > > The problems I experienced are somewhere in the application stack,
> > > either in :
> > > - Sun's 64 bit 1.5 jdk
> > > - Gentoo's glibc 2.3.5-r2
> > > - Linux kernel 2.6.16
> > > Once my current project is over (+- 3 weeks) I will be have some
> > > spare time to hunt down the culprit.
> > > Regards,
> > > Andre
> > > Andre Sachs
> > > IT Architect, Clue Technologies PTY (LTD)
> > > email: andre at clue.co.za
