c#-mapscript, zooming problem on Landsat-Layer
Tamas Szekeres
szekerest at GMAIL.COM
Fri Jun 16 10:40:42 EDT 2006
Christian,
> Know it works, the Problem realy was the metadataObj of the Layer. After a short time the Object was destroyed...the number of metadata in the Object were OK but the programm were not able to find some specific metadata information, so I get that error message.
> I solved the problem by declaring the metadata-Object as a class-Member. So now it works, but what could be the reason for that problem?
Yeah. After looking into the code i see that setting the metadata of
the layer is unsafe and to be avoided. I have posted a bug for it:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1803
Instead of creating a metadata object from scratch you should get the
reference of the HashTableObj of the layer by reading
layerObj.metadata a set the items as you have done before.
> Another problem I've got is on closing the application. Not every but often I get the following error:
> System.AccessViolationException was unhandled
> Message="Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
> Source="mapscript_csharp"
> StackTrace:
> at mapscriptPINVOKE.delete_mapObj(HandleRef jarg1)
> at mapObj.Dispose()
> at mapObj.Finalize()
You should use the latest CVS version because you are using the
layerObj(mapObj) costructor. For more details see:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1743
Best Regards,
Tamas
