MapServer 4.x; GetFeatureInfo's SRS vs CRS
Arnaud Diederen
ad at IONICSOFT.COM
Fri Jun 16 11:07:03 EDT 2006
Hi Tom,
thank you for your reply!
Kralidis,Tom [Burlington] wrote:
>MapServer doesn't support WMS 1.3.0, only 1.1.1 1.0.0, and some in
>between in ad hoc fashion.
>You're GetFeatureInfo request cites version=1.3, where it should pass
>1.1.1. What happens if you send a request like:
>http://localhost/cgi-bin/mapserv?map=/var/www/workshop/itasca.map&SRS=EP
>SG:4326&BBOX=-99.30245,43.4354,-87.36445,49.404399999999995&TRANSPARENT=
>TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=application/vnd.ogc.se_xml&WIDTH=800&HE
>IGHT=400&LAYERS=airports&STYLES=&REQUEST=GetFeatureInfo&VERSION=1.1.1&SE
>RVICE=WMS&INFO_FORMAT=gml&X=363&Y=121&FEATURE_COUNT=100&QUERY_LAYERS=air
>ports
It behaves exactly the same (the results with SRS and CRS are the same).
Regards,
Arnaud
>..Tom
>>Hello,
>>When I issue a GetCapabilities on my installation of mapserver, using
>>the following URL:
>>sca.map&service=WMS&version=1.3&request=GetCapabilities
>>I get a capabilities document showing:
>><WMT_MS_Capabilities version="1.1.1">
>>So, the service expects requests of version 1.1.1 of the WMS
>>spec, but
>>when I issue a GetFeatureInfo with this URL:
>map&SRS=EPSG:4326&BBOX=-99.30245,43.4354,-87.36445,49.404399999999995&TR
>ANSPARENT=TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=application/vnd.ogc.se_xml&WI
>DTH=800&HEIGHT=400&LAYERS=airports&STYLES=&REQUEST=GetFeatureInfo&VERSIO
>N=1.3&SERVICE=WMS&INFO_FORMAT=gml&X=363&Y=121&FEATURE_COUNT=100&QUERY_LA
>YERS=airports
>I get the following error:
><ServiceExceptionReport version="1.1.1">
> <ServiceException code="InvalidSRS">
> msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS
>must be valid for all requested layers.
> </ServiceException>
></ServiceExceptionReport>
>hmm. But then, if I change the SRS parameter name to CRS, I get a valid
>(though empty) result:
><msGMLOutput
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
></msGMLOutput>
>The weird thing is that in the version 1.1.1 of the spec, there is no
>CRS parameter for the GetFeatureInfo, but an SRS parameter. SRS was
>changed to CRS at version 1.3.
>It looks to me like a bug, am I wrong?
>Best regards,
> Arnaud
>Last Minute Addendum: When I try with the equivalent (projected) native
>logical bbox, in the native SRS (EPSG:26915, this is the Itasca demo!)
>mapserver doesn't mind the name of the SRS param. Both SRS and CRS work.
>Now, I'm totally lost o_O
>Will mapserver refuse to work properly if asked for features with a 4326
>box?
>Thanks for any information!
