script for dealing with temporary files
Bruce Raup
brauplists at GMAIL.COM
Fri Jun 16 16:51:34 EDT 2006
I see in the mapserver documentation that a suggested way for removing
temporary files that mapserver creates is a simple 'find' command:
#!/bin/csh
find /usr/local/www/docs/tmp -follow -name "*.gif" -exec rm {} \;
A problem with this is that it even removes files that have just been
created. The -mtime option to find is a bit of help if you can wait a
day to delete files, but we didn't have that option. So I wrote a
simple script in perl that allows you to specify a minimum age in
minutes a file should have before it gets deleted. I'm sure many
other people have written such scripts, probably better ones than
mine, but I thought I share mine since it's definitely better than the
above 'find' command. It's available at
http://cires.colorado.edu/~braup/software/clean_tmp_area.pl
If you have any comments or suggestions for improvement, I'd be happy
to hear about them.
Cheers,
Bruce
Bruce Raup
