What's the catch with ROSA on Windows client PCs
Ken Lord
kenlord at GMAIL.COM
Tue Jun 20 12:25:41 EDT 2006
Hi Joaquim,
I've had that problem for a long time too. At one time another member
of the community posted some code to force Rosa to refresh the map
again when the page finishes loading, which fixed the problem for him,
however I was not able to make it work.
Try searching the MapServer list archives for Rosa and my name, and
you may find the method he used. Perhaps it will work for you.
Cheers,
Ken Lord
Vancouver BC
On 6/20/06, Joaquim Pinto da Costa <jpintodacosta at gmail.com> wrote:
> Philip thanks for the reply
> On 6/20/06, Spot <spot.news at gmx.net> wrote:
> > At the point when I became frustrated by ROSA I decided to use jBox
> > instead. I did not have the blank screen problem, but I still think
> > (with some limitations) it is the better choice. Did you try this?
> No but I'll give it try, but not now :-)
> > can be forced by switching to a different window and back to the browser
> > window. Is the map then shown properly?
> The site is always the same only the client behaviour changes. Some of
> the clients indeed exhibited that behavior, you needed to move the
> window to get the content, some kind of a redraw problem. On most PC
> it works fine, after some JAVA is installed, but some of them
> (including the one where I'm supposed to make a presentation) when
> they decide not to work nothing seams to cure them.
> Thanks
> Joaquim
