WMS Spatio temporal search
Denis Nadeau
denis.nadeau at GMAIL.COM
Tue Jun 20 13:58:21 EDT 2006
I followed the instruction to set TIME and SPATIAL search from this URL.
http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
The Filter with TIME parameter works fine. My problem is that NASA ESG
portal (http://esg.gsfc.nasa.gov/) does not set the &TIME parameter in its
QUERY_STRING (File-Load View-OGC WMS Server). The results is a blank image
I want to find a way to set a default value for the TIME parameter.
Regards,
Denis
.map file
LAYER
NAME 'time_idx'
TYPE TILEINDEX
DATA "/local/tools/gdaac/TS2/www/maptest/data/AIRS/testindex.shp"
FILTERITEM 'TIME' #This work!!!
FILTER '%TIME%'
END
LAYER
NAME "AIRSRGB"
TYPE RASTER
STATUS DEFAULT
DEBUG ON
TILEINDEX "time_idx"
TILEITEM "location"
EXTENT -180.0 -90.0 180.0 90.0
DUMP TRUE
PROJECTION
"init=epsg:4326" ##recommended
END
METADATA
wms_title "Aqua AIRS Visible/NIR False Color Composite, 10 km
resolution, registered" ##required
wms_extent "-180 -90 180 190"
END
CLASS
NAME "VBRADLEGEND"
KEYIMAGE
"/datapool/OPS/user/services/cronproc/global_browse/ogc_registered/AIRVBRAD.003.20060508.day.legend.jpg"
DEBUG ON
END
END # Layer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060620/a62b743d/attachment.html
