Problem: MS4W1.5.3 with Oracle 9i
Zhonghai Wang
zhonghaiw at GMAIL.COM
Wed Jun 21 10:32:15 EDT 2006
Hi there,
I've found the problem: permission in apache.
if I start the Apache using apache-install.bat or apache-restart.bat, the
user name in the taskmanager for Apache process will be automatically set as
SYSTEM, which is not my user name, my user name is ZWA.
If I change this user name manually, MapServer works perfect with the oracle
spatial support.
if I start the apache again, I must set the user name manually again back to
ZWA. Is there any solution to set this globally?
thanks for any ideas
zhonghai
On 6/21/06, Bart van den Eijnden (OSGIS) <bartvde at xs4all.nl> wrote:
> Are there any environment variables which are not passed on to the CGI but
> are available in a DOS window? For instance how have you added the Oracle
> client bin directory to the Windows PATH?
> You also need to do this in Apache's httpd.conf using SetEnv and after
> that restart apache.
> Best regards,
> Bart
> > Hi guys,
> > I've been working on this topic for almost two weeks, and I still can
> not
> > get it work. In last two days, Fernando Simon has helped me a lot to
> solve
> > this problem, Simon, thank you, I really appreciate it. With his help I
> > stepped forward to solve this problem, but I still can not get it work.
> > according to Fernando Simon's suggestion I made the test with the
> command:
> > C:\ms4w>
> > mapserv.exe
> "QUERY_STRING=localhost/cgi-bin/mapserv.exe?&mode=map&map=C:\ms4w\apps\Demo\OracleTest.map"
> > and I get the map image successfully. In the OracleTest.map mapfile, two
> > oracle layers are defined, one with native oracle suppport, one with OGR
> > OCI
> > interface.
> > tests with the command mapserv -v and ogrinfo --formats indicate that
> > oracle
> > spatial and OCI are supported. with the "ogrinfo OCI:XX/XX at XXXX" command
> > is
> > also no problem to access the the oracle database, I can even use
> ogr2ogr
> > command to convert the oracle spatial layer to ESRI Shapefile.
> > but the problem is, if I am trying to access the oracle spatial database
> > in
> > web browse, an Internal Server Error is returned instead of the map
> image.
> > i
> > really can not figure out what the problem is.
> > thanks for any ideas to solve this problem.
> > zhonghai
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060621/dd2d9da9/attachment.html
