WMS question
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed Jun 21 11:54:54 EDT 2006
This can be accomplished using SLD. In a WMS GetMap request you can add
an inline SLD using the SLD_BODY parameter, or use the SLD parameter to
point to a URL pointing to the actual SLD XML document.
The Chameleon ExpressionBuilder widget has some code to do this or check
out:
http://mapserver.gis.umn.edu/docs/howto/sldhowto/?searchterm=SLD
If a WMS layer is queryable, you can perform a WMS GetFeatureInfo
request against it using an X and Y value in pixels, which can return a
plain text, HTML or GML document.
Best regards,
Bart
rock well wrote:
> Hi all, i have a question in WMS, can a polygon be hightlighted in a
> map in wms server, like can anything be included in the url that makes
> a certain polygon marked, for example i want the border of the polygon
> to be highlighted .... i was able to do it in mapscript but was
> wondering if the same thing can be done in WMS ...
> one more thing, i am not pretty sure what query layer does in wms ...
> Thanks for your time
> kris
> Want to be your own boss? Learn how on Yahoo! Small Business.
> <http://us.rd.yahoo.com/evt=41244/*http://smallbusiness.yahoo.com/r-index>
OSGIS, Open Source GIS
http://www.osgis.nl
