WMS question
rock well
rockwell_001 at YAHOO.COM
Wed Jun 21 18:17:46 EDT 2006
Hi Bart, i am trying to use sld_body to specifiy the path of the localurl for the xml file, but i get a blank image, i didnt really get the concept of how to write an xml file and then send it through the sld_body tag, can you suggest me with a real time example where a clear description is given as to how to specify the map file in the xml ...
well i guess i might have understood something wrong, but can you/anyone suggest me ...
i cut down my xml file to the following lines as i dont know what other lines mean
<StyledLayerDescriptor version="1.0.0">
<NamedLayer>
<Name>Layer Name</Name>
</NamedLayer>
</StyledLayerDescriptor>
Thanks for your time
kris
"Bart van den Eijnden (OSGIS)" <bartvde at xs4all.nl> wrote:
This can be accomplished using SLD. In a WMS GetMap request you can add
an inline SLD using the SLD_BODY parameter, or use the SLD parameter to
point to a URL pointing to the actual SLD XML document.
The Chameleon ExpressionBuilder widget has some code to do this or check
out:
http://mapserver.gis.umn.edu/docs/howto/sldhowto/?searchterm=SLD
If a WMS layer is queryable, you can perform a WMS GetFeatureInfo
request against it using an X and Y value in pixels, which can return a
plain text, HTML or GML document.
Best regards,
Bart
rock well wrote:
> Hi all, i have a question in WMS, can a polygon be hightlighted in a
> map in wms server, like can anything be included in the url that makes
> a certain polygon marked, for example i want the border of the polygon
> to be highlighted .... i was able to do it in mapscript but was
> wondering if the same thing can be done in WMS ...
> one more thing, i am not pretty sure what query layer does in wms ...
> kris
> Want to be your own boss? Learn how on Yahoo! Small Business.
OSGIS, Open Source GIS
http://www.osgis.nl
Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060621/b7c63d2a/attachment.html
